Found cracks in torus, best way 2 weld?
Old Mar 30, 2004 | 07:31 AM
oil pan 4's Avatar
Question Found cracks in torus, best way 2 weld?
After sand blasting (for an hout +) and parts washer I found some cracks.
2 are on the divider that seperates the waste gate gas from the turbine gas.
And one is on the torus apex (closest part that the snale thing comes to the outer most turbine blades).
Now I was going to alter this torus to flow more exhaust gas any way, it just threw me a few cracks.
I was going to heat it to 300*F + and go to work with my 135amp mig and .035'' flux core wire.
Flux core is the only way I can weld till I find out how to get a botteled gas licence over here.
What do you think is the best way to fix them?
Old Mar 30, 2004 | 07:45 PM
wingnut's Avatar
The best way to weld this would be with a TIG and a nickel rod. But this would require a shielding gas (argon).
This probably did not help did it?
Wingnut
Old Mar 30, 2004 | 09:16 PM
SMOKNZ's Avatar
Cast is difficult to weld. I've only seen it done with a stick welder, and it was heated ALOT before any arc was struck. If you don't heat it it will crack again.
Old Mar 30, 2004 | 11:10 PM
zx1216's Avatar
You prolly need to take it to a welding shop.
Old Mar 31, 2004 | 07:35 AM
oil pan 4's Avatar
For repairs the local shops usaly want about $30 per repair weld.
Old Mar 31, 2004 | 09:18 PM
wingnut's Avatar
Dude,30.00 dollars per weld on cast is a good deal. We charge more then that in our shop. But a GOOD nickel rod is expensive.
Wingnut
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
squarehead
Nov 21, 2014 08:02 PM
HuJass
18
Jun 24, 2002 09:19 PM
