T or TT?
Old Mar 14, 2004 | 08:57 AM
Heatmaker's Avatar
Advanced Member
T or TT?
After 2 Years of research and hard thinking about what to do with my engine...I've decided to go turbo.
I'd like to fabricate my own Turbo kit for my ride, but I want something unique.
I was wondering though, is it best to go with one GIant Turbo...or Two smaller Turbo's? The reason I ask this is because there doesn't seem to be hardly any room for piping underneath the hood. Especially not for a TT setup...but I've seen enough TT guys to know it can be done. I've already brought a couple Space saving items...but we'll see.
My next question is...what is best to do to the Block? How should I prep it to handle a load of around 10psi.
Is it best to stick with the 350...or for an added kick should I take it to 355 and drop the compression a bit? (allot)
Is a Turbo V8 best in 350-55 trim or should I still keep my original 383 idea in mind?
The only reason I truly decided to go turbo was cost wise. I could build myself a decent TUrbo kit for almost hte same price of my 383 kit I was thinking of purchasing. But since with the Turbo's feeding the LT.... I wouldn't need to worry about upgrading to LT-4 specs...for some extra HP. I could pretty much keep my LT-1 heads and all and just have them Ported and Decked to run on a Low compression engine. I'd figure it wouldn't matter much. I estimated I'd save a tone of money....by working with what I already got.
My next question is... who sells the sing T or TT manifolds? I've seen some floating around before...but I do not know where to look for them. It would be 100% easier to purchase prebuilt heads...that alreadu have the right angle and clearance I need to get a jump start on this.
What do you guys reccomend?
Any sources I might want to check?
Old Mar 14, 2004 | 07:09 PM
SMOKNZ's Avatar
I thought I could use a set of shorty headers, but after trying a few sets on a buddies car, it became real apparent that they would not work. Ended up building my own, it really wasn't to bad!
Bill
Old Mar 15, 2004 | 09:06 AM
mongse_1's Avatar
Take all the emissions crap and accessories off and there's quite a bit of room.
http://www.quarter-mile.net/images/T...tor_index.html
I've got a BMR k-member, Flaming River rack and a different radiator going in. There's enuff room on the drivers' side to get a 4" and possibly a 5" downpipe through.
Old Mar 15, 2004 | 01:06 PM
sleeperz28's Avatar
yup, check out the picts in my signature. Two twins up high with 3" down pipes, and thats with the factory K-frame
Old Mar 15, 2004 | 03:16 PM
JZ 97 SS 1500's Avatar
How is driving the car with no power streering? I would imagine its tough, but sure as heck would free up a good bit of room.
Jose
Old Mar 15, 2004 | 04:25 PM
mongse_1's Avatar
Skinnies and a manual rack, not too bad. Gets a little tough trying to get into a parking spot at the local Price-Mart, but how often does that happen? Wide tires though....
Old Mar 15, 2004 | 04:26 PM
mongse_1's Avatar
By chance...do you have any pics from under the car? I've seen the ones from above. Just curious.
Old Mar 15, 2004 | 06:24 PM
boosted-lt1's Avatar
A friend had skinnies and no power steering on his cougar. Not bad at all once youre moving some.
Old Mar 15, 2004 | 07:47 PM
Chrisbequick's Avatar
I'm using PTK headers, crossover pipe, and wastegate pipe on my turbo build.
-Chris
Old Mar 15, 2004 | 08:41 PM
sleeperz28's Avatar
No nothing under the car. Not much to see but intercooler tubing. Ill be snapping a few of the fuel system this week if I have it on my buddies lift ill grab a few under the car
I could not give up my power steering. Pretty much a must on a street car imo
Old Mar 15, 2004 | 09:00 PM
lt1camaroman93's Avatar
monguse are you using the pinto rack? if so what all did you need besides the kmember?
Old Mar 15, 2004 | 09:44 PM
Camaro37's Avatar
-Chris
What did they charge for those items?
Old Mar 16, 2004 | 02:49 AM
Heatmaker's Avatar
Advanced Member
Wow...didn't know so many people made thier own kits...
Old Mar 16, 2004 | 08:37 AM
mongse_1's Avatar
The rack I got is from Madman. It's a Pinto rack w/ new mounts welded on and a bump steer kit (since the Pinto is a tad narrower than a 4th-gen Firebird). I had to drill out the tapered hole on the spindles to fit the new bolts. Nothing really tough though.
http://www.quarter-mile.net/images/TA/steering/
I'm doing my own kit (large twins) because I can do it for half of what most companies would charge. $8K is nuts, especially when the turbos aren't even close to the size of the Mustang Outlaw kits that are close to the same price.
Old Mar 16, 2004 | 11:10 AM
Well, we're a PTK dealer, so I can't quote you my cost, but if I were selling them retail I would charge $1499 for them.
-Chris
