Paxton Charger Installed - What Upgrades Do I Need Now!? HELP HELP!!!!
Ok ... i just installed a 6-8 lb boost paxton s-charger and the
model i got does not require me to upgrade any engine
componets ex. pistons/piston heads etc. It is on my 93 Camaro
LT1 motor. THE PROBLEM is that now my car is downshifting at
about 2500RPM when before i had it installed it would shift at
about 1900RPM. IT'S AUTOMATIC and when i say shift i mean
when the car shifts byitself under regular driving conditions....not
speeding or racing just chill driving. Also, when i get on the gas and the RPM's hit about 4700 RPM the car backfires and doesnt shift not letting me accelerate any further unless i get off the gas and hit the gas again...get that ? shifting issue basically, car not kicking back down and allowing further accelleration
AGAIN my car is automatic and when i say shift i mean the regular shifting that the car is programmed to do.
Do i need to recalibrate my stock computer?
I'LL TAKE ANY SUGGESTIONS!!!!!!!!!!!!!!!!!!!!!!!!!!! She's a ****ing beast but i cant unleash her !!! she's being held back !!!! and i dont know why !!!!!!
stock injectors and the kit came with 3 EXTRA installed injectors that give it gas according to amount of boost ....but i had the backfire stutter problem SLIGHTLY/RARELY even before the s-charger install.....
I would highly recommend getting your chip reprogrammed. Also not to be an a-hole but you will learn that the statement below is false.
can you repogram a STOC computer ?....or do i need to get a completely different computer or chip? well the charger i got is supposed to run fine with a stock LT1.....i'm not saying it will run 4ever with the charger on it now.....but of course upgrading engine components is always the best way 2 go
For 93's there is a E-prom chip that gets reprogrammed. I would contact PCMforless.
yea i am pretty sure i do have an opti-spark......
and how do i contact that PCMforless?
if i get that chip do you think that will adjust my tranny and maybe fix it so it doesnt upshift at a high RPM like it is doing now ?
I would be easy on the car till you get it runing right. Im sure you have fuel issues and it will blow up.
My sc kit also said no upgrades needed and its total crap. Many people have blown their motors here from this reason. I would do some searchs and see what the basics are.
possible problems; lean/fuel, ignition,opti, chip
thanks for the info - yea i've been tryin to drive her easy but itz a bitch because even if i justr hit the gas normal the RPM's hit almost 3k everytime before she upshifts (automatic)...and now im leakin coolant but that is justa hose i think - goin to check it all out now...
my coolant leaked out because a hose was touching the charger pulley and the pulley sliced right through it - itz been relocated so no more leaks and the coolant is not a problem anymore.......as for the shifting issue....is shifts fine now...the injector plate that was installed behind the throttle body caused the cables to become stretched out....the cable just had to be adjusted....since it was stretched out it was holding the gear too long...so that is taken care of also.....
ONE LAST PROBLEM....when i step on it at about 47 - 5 k RPM she still stutters ...... i was told that because there is so much pressure my stock gas pump cant pump out enough gas at a constant pressure for long enough...does that make sense ?? = ) any ideas on what it may be
ummm. How about quit driving it before you blow the damn thing up. It is probably running lean as hell.
Get the tuning DONE. Do not drive it until that. If it still shutters then check your OPTI or distributer.
There is NO sense in driving/beating on the car till all bugs are worked out.
joe
joe
