Vortech questions
Old Mar 17, 2004 | 11:52 AM
EDS Z28's Avatar
Vortech questions
I'm taking my ati P600B/twin intercoolers off the car. Too many problems with the tensioner and the blower is too loud. I am going to try a vortech. My setup is going to be for sale.
The model I was going to try was the V2 SQ with the aftercooler. I had a few questions about this setup:
1.) Does the aftercooler fit under the stock hood?
2.) I planned on running 10-12 pounds of boost. What pulley combo would I be looking at. I noticed vortech offers a lot of different pulley combos.
3.) Vortech says on their website that the use of a race bypass valve is necessary for 10 pounds of boost or more. How would the race bypass be installed, ie. would it just bolt-on or require some custom work?
4.) Would a solid intake pipe be necessary? Where do I get one of those. I made my own for the ati.
Thanks-a-lot,
Ed
Old Mar 17, 2004 | 05:53 PM
LWM's Avatar
LWM
The vortech intercooler does indeed fit under the hood ... http://www3.telus.net/public/mackenz...oEnginebay.jpg
I am currently running a 3.125 x 7" set up and I see 8psi of boost at 6,100 rpm on my 383 setup. If I'm not mistaken, the largest crank pulley Vortech offers is a 6.66" and the smallest blower pulley is a 2.75", that may get you to 10psi. To get to 12 psi of boost you may need a T-trim.
I ran the stock vortech 6psi S-trim bypass valve at 11psi for a year and a half, no issues.
A solid intake pipe would be of great value. Mine is a Brad Brandt pipe. I'm sure there are others available.
Hope this helps
LWM
Old Mar 17, 2004 | 07:11 PM
TravisA's Avatar
Why not just sell the p600b head unit and try and find a d series procharger. That way you should be able to use your current intercooler setup?
I've heard the D series is quieter than the p600b? I personally do not know this.
Travis
Old Mar 17, 2004 | 08:55 PM
94SLUG's Avatar
Travis
I cant hear my blower after 3min of run time. Never had a problem with my tensioner either.
Old Mar 18, 2004 | 06:48 AM
IDOXLR8's Avatar
Travis
I have owned an F1, D1SC and P600b. By far the P600b has been the loudest. I would say the D1SC has been the quietest.
Old Mar 18, 2004 | 07:26 AM
Blownbird355's Avatar
I have an S-trim with the stock pullies (not sure what size) and I see anywhere from 10 to 12 psi depending when the tranny decides to shift. I shoot for the 6k shift but they are not consistant. Also this kit was supposed to be the 7psi kit. But I believe I got the 9 psi kit. I wouldnt worry to much about the larger bypass initially but maybe plan it to be safe.
Old Mar 18, 2004 | 09:34 AM
EDS Z28's Avatar
After taking the ati blower stuff off yesterday, it is amazing how much room there is now
I have always had problems with the tensioner, so have others. It is just poorly designed. I don't know about the other ones on the P1 or D1 though. I really like the idea of helical cut gears in the Vortech. Paxton has a great blower too with these type of gears (Novi 2000), but they do not make a bracket.
After looking at a compressor map of the s-trim on vortech's website. it appears the s-trim can make up to 12 pounds of boost, but with slightly less efficiency (around 70%) than if you ran 8 pounds of boost. I will be calling Vortech today and get their recommendations.
You have to wonder about how effective those small ati intercoolers are. They are only 6"x9"x3.5" deep. A lot of piping too. I don't really like how they designed the 2-into-1 pipe leading to the intake. It is too close to the radiator and antilock brake unit.
Old Mar 18, 2004 | 11:35 AM
1st and goal's Avatar
I agree, I'm a tad dissapointed that my D-1 doens't sound like my old trusty P600B I never had problems with my tensioner on the P600B but the one that came with the D-1 kit sucked. I had to take it to SD-concepts to cure what ailed it.
Marc
Old Mar 18, 2004 | 06:48 PM
TimChiaretto's Avatar
Yeah, everything fits under the hood just fine. There isn't any room left but then I guess we are used to that. Take a look at my web site to see the fitup I did.
LWM, where did you get your 7" pulley?
Old Mar 18, 2004 | 07:04 PM
EDS Z28's Avatar
Tim,
Great job on the inlet pipes. I may end up doing that also. What was the problem with the MAF being on the non pressure side? With my ati, I got some surges here and there, so it got relocated to near the t-body like yours.
How do you like the performance of the vortech and the aftercooler? How much boost are you runnin?
Thanks,
Ed
Old Mar 19, 2004 | 07:12 AM
LWM's Avatar
LWM
I got it from Vortech, but that was in early 2,000 the biggest they sell now is the 6.66 crank pulley. The stock crank pulley is 6" I believe.
http://www.vortechsuperchargers.com/.../merchant.mvc?
LWM
Old Mar 19, 2004 | 08:12 AM
Ed,
There wasn't any problem with the MAF on the non-pressure side, I just like it in the stock location and wanted the blow off to vent to atmosphere instead of being recirculated.
At 6 lbs of boost I wasn't overly impressed, it ran nice but wasn't the monster power I had hoped so now I am building another motor with forged pistons and a few other goodies and want to go to 10 lbs of boost. That should give me the kick I am after.
Old Mar 19, 2004 | 07:16 PM
EDS Z28's Avatar
Well, I ordered the Vortech today from T-byrne. They had the best price.
I will let CamaroZ28.com know what I think about this kit upon installation. I am going with a stock vortech blower pulley and 6.66 crank pulley. This way the blower is under a 3 year warranty. I am looking for around 10-12 pounds of boost. This should get interesting because I have the dyno numbers from the ati. If there are any more recomendations please let me know.
BTW, I love the idea of a pretty quiet blower, the ati I have is ridiculously loud, good for a teenager.
If anyone is looking for the ati twin intercoolers or P600B blower, I have it available.
Thanks,
Later Ed
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
onefastgta
Mar 19, 2015 10:10 AM
dansam
Jul 20, 2002 01:10 PM
Brent94Z
Mar 21, 2002 04:44 PM
