MAF on pressure side
I read that many people are starting to do this to their cars but from what i have seen, it has on been on ATI's or car with some sort of intercooler routing. I have a STrim with the factory routing and was wondering if anyone had some pics or if it even will work. Was there anying cutting of the composite discharge tube is my main question. Im running water injection and the nozzle is in this tube and need to know if i have to move it. Also, putting the MAF on the pressure with the water injection would mean that the water would pass over the MAF sensors. Is this okay or would i have to move the nozzle after the MAF. Thanks for any replies.
Ray
Ray
i can't help with the details on squeezing it in that small space on a vertech setup, but mine is on the pressurized side as well, with a surge valve venting to atmosphere 6 or so inches before the MAF. I haven't had any problems at all with it.
The water injection would absolutely have to be done after the MAF, not before.
Maybe Im wrong but i thought that the water took the place of air so wouldnt it be more accurate if it was before the MAF, i know the obvious no no of putting water on electronics but the water is basically steam in the motor because of the heat so would it have the same effect? Any input from someone in the same boat would be good.
Ray
Ray
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
