increase timing
Old Jul 24, 2006 | 12:11 AM
ssean92's Avatar
increase timing
i just got the tunercat program and was wondering if adjusting the timing would get me any gains or should i not mess with it at all???? stock lt1 cam
Old Jul 24, 2006 | 09:19 AM
ssean92's Avatar
Re: increase timing
no one?????????????????????
Old Jul 24, 2006 | 09:33 AM
Dave '97 Z28 M6's Avatar
Re: increase timing
Providing you're running 94 octane, you could push the timing envelope a bit and gain a few HP. As long as you don't go too wild, and still have a functioning knock sensor / knock retard, the computer will dial things back if detonation occurs.
Old Jul 24, 2006 | 09:35 AM
ssean92's Avatar
Re: increase timing
thats kinda what i was thinking but just wanted to be sure thanks for the reply
Old Jul 24, 2006 | 10:05 AM
Re: increase timing
If you use a scanner/datalogger and monitor knock retard, you'll be able to tell when you've gone too far.
Old Jul 24, 2006 | 10:10 AM
ssean92's Avatar
Re: increase timing
yes i do and thats a good idea, thanks
Old Jul 24, 2006 | 10:18 AM
VK's Avatar
VK
Re: increase timing
Yes, you can gain alittle bit because of the stock timing is alittle on the tame side so u can run lower octane. If you do advance the timing, make sure you run better gas, otherwise you'll just get lots of knock retard and make your car run worse.
Old Jul 24, 2006 | 10:55 AM
Sweetred95ta's Avatar
Re: increase timing
You'll get some power by leaning it out some at WOT. The factory tune is pretty fat. You would have to ask someone who has more experience tuning stock cars and find out how much you can lean it out.
Old Jul 27, 2006 | 09:34 AM
ssean92's Avatar
Re: increase timing
i have a tune in the computer now, it adjusted the wot and part throttle fuel settings, and i only use 93 oct in my car. i plan on getting the cc306 cam soi will just wait till them to mess with the timig thing, and also will the stock injectors work with that cam????
DirtyDaveW
Dec 1, 2016 05:37 PM
Richardan15
May 30, 2015 08:36 AM
Jan 23, 2015 01:13 PM
centric
Aug 15, 2002 09:04 PM
Fastbird93
Jun 30, 2002 05:49 PM
