"VATS" I need help with resistance!(shoebox)
Old Jul 21, 2006 | 11:35 AM
DarinsTA's Avatar
Question "VATS" I need help with resistance!(shoebox)
I talked to the dealership to get the resistance of the chip in th key. Oh , I am working in a 96 cadillac fleetwood. They salvage yard lost the key and broke the column. Anyway I talked to the guy at the dealership to get the resistance across the key. His exact words were "it uses the 05 chip". I said ok and hung the phone up. But when I checked shoebox's website it doesn't list an 05 ohm resistance, what did he mean? The place is close already, so I can't call back. If anybody can help it would be appreciated. As I am not very savy on the whole ohm readings.
I have a multimeter.
Old Jul 21, 2006 | 12:43 PM
StickMaster's Avatar
Re: "VATS" I need help with resistance!(shoebox)
I got bored and did some searching for you...
Looks like according that table Key Code 5: 1130Ohms (1085Ohms-1195Ohms)
http://fordfuelinjection.com/files/TFI_Tips.pdf
Old Jul 21, 2006 | 12:56 PM
DarinsTA's Avatar
thanks for the reply I will see what I can do.
Old Jul 22, 2006 | 08:46 AM
He meant use pellet code 5 from my chart.
Old Jul 22, 2006 | 09:50 AM
DarinsTA's Avatar
thanks, I bought a couple of resistors and came up with exactly 1130 ohms. I put it in line and the pass fault light went out. But It still WON'T attempt to crank. I am going to check other things. Is there any other thing specific I should check?
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Aug 17, 2015 09:50 AM
