How to get trouble codes from a '95
Old Aug 11, 2006 | 12:01 AM
engineermike's Avatar
On OBD1 stuff, you could always jumper pins A and B to get the codes, however, the 1995 OBD1 has an OBD2 16 pin connector and the A and B pins don't exist. What do I have to jumper to get the codes out of my computer?
Mike
Old Aug 11, 2006 | 07:21 AM
moparman's Avatar
Re: How to get trouble codes from a '95
You can't flash the codes on the '95. The '93 models were the last you could flash. You will need an OBDI code reader or scan tool with the proper cable, or there is a way to use an OBDI code reader or scan tool by using jumpers, as shown on shoebox's site. Or, if you have a laptop and proper software and cable, you can use that.
Old Aug 11, 2006 | 10:30 AM
race u 2's Avatar
you could always take it to a parts store like autozone most of them will hook up to the computer and read the codes for free
Old Aug 11, 2006 | 11:53 AM
Sweetred95ta's Avatar
Most have trouble because they don't have the OBDII connector for the OBDI scanner. You can use the jumper method on Shbox's website as suggested by moparman. I don't know if Autozone would let you sit there with their scanner and jumper the connector though. I'd recommend buying a cable ($45) and using Freescan (free) with a laptop.
Old Aug 11, 2006 | 12:25 PM
Got it taken care of. I already do all my own tuning and had a cable. My home-built scanner won't read codes. I simply downloaded FreeScan and found out that the computer is issuing code 24, output speed low. I think this is because my VSS is not hooked up.
Mike
Old Aug 13, 2006 | 02:11 PM
drpz28's Avatar
i also have a 95 z28. where can i get that cable and software to scan it with my laptop?
Old Aug 19, 2006 | 04:01 PM
You can get the cables from www.moates.net. Do a google search for freescan and you can download it free off the internet.
Old Dec 18, 2006 | 04:24 PM
jackalz28's Avatar
Hate to bring up an old thread but all the websites I've been to have the cable at $80 and above. Anyone know where I can find one for $45 as specified earlier in the thread? Thanks
Old Dec 19, 2006 | 10:32 AM
AKM sells a "kit of parts" for $45.
http://www.akmcables.com/ic.htm
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
