who all has...obd2 swap 94
swappd from obd1 to obd2 in a 94...with the obd1 connector???
i have a madz28 obd2 computer..
i have a obd2 knock sensor...installed it...(swapped wire #20 to spot # 7 in the blue connector (tried it both ways) put the computer in and have a check engine light(runs like crap converter wont lock barely idles) ...problem is i want to be able to scan it, ive connected
9 to m
5 to a
2 to b
8 to g
16 to power
plug in a scanner and it says that it has no link or something, i cannot even get a basic reading, although i know it has power and ground bc the scanner powers up, so is there a way to bypass the underdash port to get a quick reading such as power ground and signal (2 or b)
http://shbox.com/1/dlc1.jpg
will that work..or do i have to have, 9m 8g hooked up too...?
hoping to get some help...i have a volt meter so i can test some stuff also
9 to m
5 to a
2 to b
8 to g
16 to power
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
