MAF, SD or PE tune please help
Old Aug 20, 2006 | 08:55 AM
viper03af's Avatar
OKay first this is a V6
Problem 1
HP does not offer the ANY SD stuff for the v6er's, i asked them to make me only a custom file for MY car and they turned me away
Problem 2
The VE table in the PCM stops at 140kPa. so this will only alow me to add fuel until ~15psi boost, problem is i'm at 18 already
So i think this leave me with MAF only
the PCM stops at 11,500 Hz (37lb/min with stock maf) and like any other GM pcm it maxs at 512g/s
so since the LS1 and all those don't flow to much more then mine at 11,500Hz or only let me run 2-5 mor psi..
i found this
http://cgi.ebay.com/ebaymotors/Mass...sspagenameZWDVW
that or i need to find someone to do a custom MAF curve for me...........
there are also MAFT but i don't know if i want to trust those or not
so any advice ?
right now i'm adding the in the FUEL in PE after the maf maxs and its HUGE PITA have to retune for different air temps and would rather not have to go this route again
Old Aug 21, 2006 | 06:13 PM
viper03af's Avatar
Re: MAF, SD or PE tune please help
Ttt
Old Aug 22, 2006 | 08:12 PM
mkent's Avatar
Your ebay link does not work.
I know this is not what you're looking for, but have you looked into the Megasquirt systems?
Old Aug 22, 2006 | 08:30 PM
viper03af's Avatar
they don't support our waste spark for the timing last i checked
Old Aug 22, 2006 | 08:33 PM
viper03af's Avatar
http://cgi.ebay.com/ebaymotors/Mass-...spagenameZWDVW
Old Aug 22, 2006 | 10:18 PM
busta9876's Avatar
http://www.megamanual.com/ms2/GM_DIS.htm
goodday.
Old Aug 23, 2006 | 07:16 AM
viper03af's Avatar
Originally Posted by busta9876
so iguess it works now? befor you had to convert to ford EDS and use it like that
DirtyDaveW
Dec 1, 2016 05:37 PM
FieroLT1
Jun 26, 2015 08:43 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
