Can ABS be disabled by tuning?
Old Jul 26, 2006 | 04:30 PM
Vicious95Z28's Avatar
I know that there are kits offered by SJM manufacturing to file 13 the ABS module under the hood, but can the pcm be tuned to disable the in dash ABS light?
thanx
Vicious
__________________
Old Jul 26, 2006 | 08:53 PM
sbs's Avatar
sbs
Re: Can ABS be disabled by tuning?
thanx
Vicious
__________________
I just looked and I don't see anything related to ABS error codes in TunerCat ($EE).
Old Jul 26, 2006 | 10:28 PM
madwolf's Avatar
No.
Old Jul 27, 2006 | 03:22 AM
tapout911's Avatar
I have the kit from sjm and in the instructions it tells what wire to ground to disable the dash light. If you need it, ill dig the papers out.
Old Jul 27, 2006 | 06:26 AM
TQdrivenws6's Avatar
I would be interested in what wire to ground, it wasn't in my instructions.
Old Jul 27, 2006 | 09:22 AM
The ABS has it's own computer.
Old Jul 27, 2006 | 12:12 PM
tapout911's Avatar
To disable the abs light:
Locate the ebtcm under the drivers side kick panel. This box can be removed if you want. You must ground the warning lamp wire that is in the harness that plugs into the ebtcm. Its a light green wire located on the b2 connector. To ensure you are looking at the correct connector, next to the b2 connector position b1 will be dark green, b3 will be pink, a1 and a2 will not have anything connected to it. Just splice into it or cut it and ground it from the dash side of the wire.
Old Jul 28, 2006 | 04:11 PM
[QUOTE=tapout911]:
This box can be removed if want you.
As in permanently?
88IROC_Z
Jul 22, 2015 11:38 PM
mrwz28
Jul 8, 2015 09:11 PM
CARiD
Jul 7, 2015 08:19 AM
