Tuner Cat Timing tables
Old Aug 21, 2006 | 11:26 AM
Red on Red WS6's Avatar
I have a couple of questions. I am using Tuner cat OBDII and I can't find any files other than stock I can compair, does anyone have a .cal file they would like to share? Is there any website you guy's know of that has file sharing for OBDII. My main objective right now is to get a good timing table setup. I get false knock, I think it is from my headers so I desensitized my knock sensor under WOT but I am only running 35 Degrees of timing at WOT is this does this sound right for a hot cam 91 octain.
Also I have a buddy that has a stock LS1 and I just bought the definition file for his car and I am wondering how much timing would be ok to add? And should I add some accross the board or only on the top end?
Any help is greatly apreachiated.
Old Aug 21, 2006 | 12:58 PM
97WS6Pilot's Avatar
Re: Tuner Cat Timing tables
I think you need to use 93 Octane but here is my timing table at 100KPA. This is when I was Normally Aspirated.
100Kpa
8.0 400rpm
8.0
14.0
16.0
18.0
20.0
21.0
24.0
27.0
32.0
34.0
35.0
36.0
37.0
37.0
37.0 4000 Rpm
37.0
37.0
37.0
40.0
30.0 7000Rpm
Old Aug 25, 2006 | 07:44 AM
roughneck427's Avatar
Go to www.mondax.com check out the file request section
DirtyDaveW
Dec 1, 2016 05:37 PM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
jrp4uc
Jun 19, 2002 06:20 PM
