tuning software for 95 obd1 computer
Old Aug 22, 2006 | 06:27 PM
99transamc/fia's Avatar
What i'm looking for is the software for tuning a 95 firebird with obd1 computer and obd2 connecter in Speed Density.Is this even possible?
The motor is a 383,ported stock heads 285+cfm @.600 lift 53 cc chamber ,intake to match, comp cam .584in .579 ex @.05 242in 248 ex 113 ls, 12.45:1 compresion,42 lbs injectors.
This car is basically a race car,but i will Drive it to the track somtimes.
Old Aug 22, 2006 | 08:02 PM
sbs's Avatar
sbs
Re: tuning software for 95 obd1 computer
Same as any other 94-95 car. Tunercat and LT1edit are the usual options.
Old Aug 28, 2006 | 09:05 PM
Airbornec507's Avatar
With that sort of combo I would get a good base line tune from pcmforless.com or madz28. Reason I say this is due to the higher compression and massive injectors. A mail order tune will run you around $75 from pcmforless and the ALDL cable will run you $95 from http://www.akmcables.com
Once you have a base tune to work off of you can tweek it to get a few extra tenths out of it.
You realy don't need a mail order tune if you know what your doing with the software. However, I will not be able to offer any help on the tune myself due to deployment(this is my last day of internet for a while). There are a ton of very knowledgable folks on this site though who can help you out on a personal tune. I can tell you though that they will want you to do some digging first and come back with questions. G/L!
DirtyDaveW
Dec 1, 2016 05:37 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
