dtc 51 bad checksum
Old Aug 23, 2006 | 09:30 PM
Blownbird355's Avatar
dtc 51 bad checksum
I have a Datamaster scan where in the middle of the scan I get a DTC 51 bad checksum. If the checksum was bad wouldnt I get it throughout the scan?
Old Aug 24, 2006 | 10:16 PM
Re: dtc 51 bad checksum
WTF whats a guy got to do to get a little help on this board. Are my titles not good enough or are my probs that out of the ordinary?
Old Aug 26, 2006 | 08:05 AM
this board sux
Old Aug 26, 2006 | 02:12 PM
94CamaroZ28's Avatar
Maybe no one knows the answer. It may be a bug in the program, i'sd shoot and email to the Datamaster programmers and inquire.
Was it that one time only, or does it happen every run? once, I'd go for a momentary comm glitch.
Old Aug 26, 2006 | 02:33 PM
Its only after car runs for so long. Datamaster support sux.
Old Aug 29, 2006 | 10:22 AM
madwolf's Avatar
Sounds like you can use a reflash because your current tune might be corrupted. If your car is stock, find a known good stock tune (if you send me your VIN, I can send you one too) and load that into it.
You should be a little more patient. People don't reply that quick in this section and as for Datamaster, although they do take time now, it really isn't a Datamaster issue.
Old Aug 31, 2006 | 01:57 AM
Was frustrated. What would make it come up bad checksum towards end of scan. Car is not stock tune. I have a saved copy of the tune thats in. I just need to send pcm off just to make sure its not the prob. I have a laptop but I cant get it to communicate with lt1 edit.
Old Sep 2, 2006 | 12:59 AM
turbo_Z's Avatar
Ive seen that code pop up from time to time and its just a minor hicup as far as I can tell.
Hell if you think that is bad. Sometimes my computer will not even power up on the first try.. had that happen once. Then several times it has defaulted to 1 degree of timing which still has me puzzled. I notice these errors when the computer gets a lot of heat soak from driving around town. Ill park it for a minute to get gas or whatever and start it back up with 1 degree of timing or up to 5 when I rev the motor. Thankfully though it usually comes back if I shut it down and restart. Weird stuff.
KYWes
Jun 14, 2022 06:52 AM
Boss002
Jan 20, 2016 12:17 PM
Jmj93z28
Jul 10, 2015 06:37 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
