knock retard
Old Oct 6, 2006 | 03:07 PM
kline454's Avatar
knock retard
knock retard
My camaro is pulling 1degree of time at idle and 2 degrees at wot, I replaced my knock sensor same thing and my knock module with no diff made, i also checked my wire to my knock sensor it has the 5v with wire off like it should and the sensor has 3800ohms of resistance and spec is 3500 to 4500 so thats good. so i put a resistor 3800ohm from the wire to ground. and the car still pulls 1 degree at idle and 2 degrees at wot, any know why this is?
__________________
1995 Z28 Long tube headers hooker off road Y,cat back,cc503 918 spring,1.6rr 58mm TB MSD 6A,2400stall 3.73,1.99 60ft 13.12 @105.37
Old Oct 6, 2006 | 05:05 PM
kline454's Avatar
Re: knock retard
Anyone?
Old Oct 6, 2006 | 07:43 PM
kline454's Avatar
Re: knock retard
Replaced PCM no diff made.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
