scanner results
Old Oct 3, 2006 | 09:26 PM
Purplemaroz28's Avatar
scanner results
this scans from 4345rpm to 6408 and then letting off
cells stayed 15
blm stayed 128
left o2s
925 4345
921 4428
916 4565
898 4923
876 5555
836 6105
792 6408
right o2s
792 6408
863 6380
890 5885
baro. fixed at 5.0v
spark advance
36 4345
37 5115
36 5198
37 5308
38 5913
39 5994
no knock
MAP
4.84v 4345
4.72 5390
4.5 5995
4.56 6298
4.64 6408
mat stayed 71
IAc stayed 118
airflow
210 gm/sec 4428
232 4730
267 5308
301 5913
311 6105
328 6298
should the iac be moving by the way this is with a 383 and 5.7" rods
Old Oct 4, 2006 | 09:38 AM
Re: scanner results
cells stayed 15 - Normal
blm stayed 128 - Normal (a question - are you running a closed loop tune or an open loop tune? The BLM's will stay at 128 for two reasons, one being an open loop tune, and the other being the case where the BLM's in the high load cells are "reducing" fuel.)
left o2s
925 4345
921 4428
916 4565
898 4923
876 5555
836 6105
792 6408 - Recognizing that the data from the O2 sensors is not very accurate at the typical WOT A/F ratio, it appears that it may be leaning out over 5500rpm. Might want to check your fuel pressure at 6,400rpm/max load.
right o2s
792 6408
863 6380
890 5885 - still leaning out, but maybe not as much
baro. fixed at 5.0v - Normal
spark advance
36 4345
37 5115
36 5198
37 5308
38 5913
39 5994 - depends what the progammer set it at. Normal for it to increase as RPM goes up.
no knock - good
MAP
4.84v 4345
4.72 5390
4.5 5995 - looks a bit low... about 92kPa. Means you are possibly losing 10kPa in the intake system.
4.56 6298 - minus 9kPa
4.64 6408 - minus 7kPa better, and roughly 2"Hg vacuum, which represents a reasonable loss. The higher you can keep the MAP, the more power it makes. Check the filter, see if it needs to be cleaned.
mat stayed 71 - good
IAc stayed 118 - normal. No, it should not be moving. It opens up as RPM increases, to a point, to prevent the engine from stalling if the throttle blades suddenly close.
airflow
210 gm/sec 4428
232 4730
267 5308
301 5913
311 6105
328 6298 - Are you making about 400 flywheel HP?
Old Oct 4, 2006 | 10:23 AM
seawolf06's Avatar
Re: scanner results
What did you scan with?
Old Oct 5, 2006 | 08:47 PM
Re: scanner results
snapon 2500 the brick
Old Oct 5, 2006 | 08:56 PM
Re: scanner results
left o2s
925 4345
921 4428
916 4565
898 4923
876 5555
836 6105
right o2s
792 6408
863 6380
spark advance
36 4345
37 5115
36 5198
37 5308
38 5913
no knock - good
MAP
4.84v 4345
4.72 5390
airflow
210 gm/sec 4428
232 4730
267 5308
301 5913
311 6105
i BELIEVE it is running in closed loop tune it is a madz28 tune
i am going to buy a fuel pressure gauge because i was concerend with that very thing.
my intake system is new (moroso CAI and new 58mm tb)? What else could be causing the lose? bad sensor?
I hope to be making that amount if not more thats why im worried about my tune. i know the shorty headers are holding me back but.... i would like to think not this much
Old Oct 7, 2006 | 02:20 PM
Re: scanner results
bump
Old Oct 9, 2006 | 10:39 PM
Re: scanner results
Nayr
Mar 3, 2023 08:34 PM
HAWG
Sep 25, 2015 11:41 AM
plattted
9
Sep 20, 2015 11:23 AM
