freescan???
Old Jul 18, 2006 | 08:32 PM
95zsean's Avatar
freescan???
Will it work on my 95Z and where is the best place to get it?
Old Jul 18, 2006 | 09:24 PM
93camaroLT1's Avatar
Re: freescan???
You can get it here:http://www.andywhittaker.com/ECU/Fre...0/Default.aspx
Let me know if you can it to work, cuz when I downloaded it didn't have ANY definition files, so it would let me select ANY car to scan.. But the only real advantagea of freescan is that you can reset your IAC and change you desired idle rpm, which you can not with datamaster which you can also get for free..
Old Jul 19, 2006 | 07:40 PM
95zsean's Avatar
Re: freescan???
I will try to download it tonight.Did you get it to work?Also where did you get the cable to adapt it to the car? I found a site AKM Electronics it sounds like a good company,came recomended by MadZ28.com. Thanks
Old Jul 19, 2006 | 08:29 PM
Re: freescan???
I can't get it to work, if you get it too work, let me know what you did.
Any aldl cable should work, I had a lot problems with just using a normal aldl cable to a 9 pin and then using a USB converter, so I just bought the direct aldl to USB cable from moates which worked effortlessly on the first try.
Old Jul 19, 2006 | 09:59 PM
Re: freescan???
I believe the idle speed change is only temporary (during your test session). Freescan is not a programmer.
Old Jul 19, 2006 | 10:45 PM
Dave '97 Z28 M6's Avatar
Re: freescan???
That's right. And I haven't actually even been able to do that with it, possibly due to my USB > RS232 > ALDL cable (although it scans/logs fine). I use Datamaster myself, but I've tried Freescan, and it works well.
Old Jul 21, 2006 | 03:33 AM
JustNO's Avatar
Re: freescan???
dead link ??
Old Jul 21, 2006 | 07:30 AM
Re: freescan???
Originally Posted by JustNO
dead link ??
Works fine for me.
Old Jul 21, 2006 | 08:12 AM
95zsean's Avatar
Re: freescan???
In the licence aggrement it asks you to Email andy if you download it from him I guess he will send you the codes to make it work? i havent tryed it yet.
fs@andywhittaker.com
Old Jul 21, 2006 | 08:32 AM
Honda Hunter's Avatar
Re: freescan???
It's been wierd. I had issues with it but I dont remember what i did to solve it. A friend of mine still cant get it to work.
Old Sep 6, 2006 | 07:03 PM
slp223's Avatar
Re: freescan???
i had a working copy but my laptop died and now when i dowload it i have no luck. can anyone email me a working copy.
Old Sep 6, 2006 | 07:16 PM
GALIATHON's Avatar
Re: freescan???
whats your email Address
Old Sep 7, 2006 | 07:56 AM
Sweetred95ta's Avatar
Re: freescan???
You're not trying to use it on your 93 are you?
Old Sep 7, 2006 | 10:06 AM
slp223's Avatar
Re: freescan???
rj_kutz@hotmail.com
Old Sep 7, 2006 | 10:35 AM
GALIATHON's Avatar
Re: freescan???
email sent Let me know if it works 4 you..
