obd2 t0 obd1 conversion
Old Aug 10, 2006 | 11:46 AM
vdubois's Avatar
okay im converting my obd2 to obd1 so i can modify settings myself. I have a 96 z28. What type of connector will i need to hook my laptop to the car. Is the odb1 and obd2 connector the same. Ive been reading through the posts and cant find anything.
Old Aug 10, 2006 | 04:49 PM
Dave '97 Z28 M6's Avatar
Re: obd2 t0 obd1 conversion
You still need an OBDII-style connector for the laptop cable. An OBDI converted '96 or '97 F-body ends up basically like a factory '95 F-body, OBDI PCM with an OBDII connector.
Old Aug 11, 2006 | 01:27 PM
MTBeni's Avatar
Thats what I did. I got a USB cable from akmcables. Works great.
Old Aug 17, 2006 | 07:26 AM
Shawns30thAnnZ's Avatar
what do you benefit from switching to OBD1?
Old Aug 17, 2006 | 09:51 AM
vdubois's Avatar
it is a lot easier to work with the obd1 setup. I can download the software very easily and it is extremely inexpensive. I will be able to do all my own reprograaming with my laptop. If you have obd2 you either have to send it off or spend big $$$$$$$ to program it yourself.
Old Aug 17, 2006 | 03:06 PM
isnt the lt1 edit availible for the 96-97 LT1? i believe its only $300-$500 for 1 pcm.
Old Aug 17, 2006 | 08:49 PM
True, OBDII LT1edit sells for $450, compared to $200 for the OBDI version. But OBDI Tunercat can be bought for $90.
Old Aug 17, 2006 | 10:28 PM
ok, so is there a performance benefit to either? or just peoples preferences and wallet depth.
Old Aug 18, 2006 | 05:16 PM
Clean97Z's Avatar
I have the same question. What are the true benefits of moving to OBDI other then the cost of the software? Is OBDII a problem with a H/C setup? Something like a LE2 setup?
Old Aug 19, 2006 | 03:15 AM
Some of the tuners state that OBDI is less troublesome to work with (less codes), and usually yields a few more HP. Some people complain that the OBDII misfire detection is set off by more radical cams.
I went to OBDI for the easy/cheap availability of interface cables and software.
In some states/juristictions that require emissions testing, they will plug into an OBDII computer to check for the PCMs readiness indicators - you'd fail that test if you had OBDI in your OBDII car. This is not a concern if you have to do a sniffer test instead.
Note that some people have issues with OBDI and high-stall torque converters - obviously not a concern with us 6-speed guys.
Old Aug 19, 2006 | 10:21 AM
JustNO's Avatar
Go OBD1 Conversion with ION (www.madz28.com), and get your cable from Andrew (www.akmcables.com).
Mmm thats all.
Old Aug 19, 2006 | 10:35 AM
will the light go on KOEO and go away with the engine running with the OBDII to OBD I conversion?
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
