Need a little advice...trying tuning on my own
The car is a 383 LT1 with a P1-SC and Alkycontrol and Im hoping to see about 12 psi
I have a basic base line already. What I am looking to do is check my a/f ratio and play with the timing a little since my latest round of mods. Would it be better to use the v/e tables to get my fuel where I want it first and then mess with the timing? If not whats the best way to go about it?
I want to get right around 11:1 and if I need more fuel then I want to increase my methanol but if I need less fuel then I want to take fuel out of the ve tables.
As far as timing go can I just increase timing a couple of degrees across the board until I get knock or the horsepower levels off and then back it of a couple of degrees just to keep it safe?
What do you guys think
Re: Need a little advice...trying tuning on my own
Do you have a wideband to check your A/F? Usually timing adjustments need to be done first then fuel although if fuel is way off you'd want it close before timing adjustments.
I've always worked the other way around. I get the fuel as close as I can, and then adjust the timing. Why do you want the a/f at 11:1? If you're going to adjust your ve table for fuel, I take it that you're running a closed loop, speed density tune?
Originally Posted by wicked_95z
Oh, I know better than that. I planned on doing it at one of the local dynos that have a wideband
That is very true. Im just a little gun shy after toasting my last motor trying to tune it on my own because no one around my area knows how to do it. I know the basics but apparently not enough
Well it was kind of weird. I was adjusting the % change @ WOT tables. I tired increasing the values and it wouldnt get any richer then I tried decreasing the value and it got a little richer so I kept going but it never got an richer than that. I was just running it way to lean. Im pretty suire I was just out of injector. I only had an expired version of datamaster at the time so I couldnt check my inj dtc. It finally gave up on me while racing my brother in law on hjis gsxr
I have thought about that. Just not too many 94-95 cars around here anymore. But it would be nice to make a little cash on the side and quit paying others to do something I have the equipment to do
Aug 24, 2015 06:41 AM
