OBD1 forced induction/maxed maf issue
Old Sep 20, 2006 | 04:46 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Ok, I've now run into the 2nd car I'm having this issue with.
OBD1 LT1, supercharged. When the MAF sensor maxes out the injector pulsewidth stays at the same value momentarily, than quickly drops off. The PE table is having no effect after the maf sensor maxes out.
For example, injector pulsewidth will ramp up and be at around 15ms at the time the maf sensor maxes, shortly thereafter it will drop to 13/10/9 resulting in a lean condition. (all while the PE table is commanding more fuel).
I have not had this issue with OBD2 LT1's. What am I missing?
Old Sep 20, 2006 | 07:00 PM
97WS6Pilot's Avatar
Re: OBD1 forced induction/maxed maf issue
Never had this problem with my OBD2. I wonder if it is slipping out of PE mode for some reason. You might try adjusting the %TPS for WOT table to 0 at that RPM to see if it solves the problem. Also I would check to make sure it is staying closed loop. Sometimes when the computer detects a malfunction it goes to open loop.
Drtryder
Apr 22, 2015 04:17 PM
BigWil
Mar 29, 2015 12:24 PM
CARiD
Jan 27, 2015 06:27 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
