OBD-1 won't scan
Old Oct 1, 2006 | 12:39 PM
milz's Avatar
OBD-1 won't scan
I just bought an unmodified 94 Z-28 and the check engine light comes on as soon as I begin to move the car and also the cooling fan comes on. I tried to pull the codes and all that happens is that the cooling fan comes on, never even get a code 12. The car runs normal besides the fan staying on. The fan does shut off when I come to a stop. Any help would be appreciated!
Old Oct 1, 2006 | 01:03 PM
2001NBMZ28's Avatar
Re: OBD-1 won't scan
You using a scan tool or trying to flash it at the DLC? Thinking '93 was the last year you could flash codes.
Old Oct 1, 2006 | 01:04 PM
milz's Avatar
I'm using a scan tool.
Old Oct 1, 2006 | 01:13 PM
...not a real scan tool if you are looking for a flash of code 12. You can't do that on a 1994. You need a real scanner.
Old Oct 1, 2006 | 01:15 PM
Dennis93TA's Avatar
On my 93 as soon as my SES light comes on the fan comes on. It ended up being the EGR system. I read in the GM service manual that certain DTC's will automatically turn on the fans. It sounds like that code only comes on at certain times. Also when i flash the codes on mine the fans cut on while you are flashing.
Old Oct 1, 2006 | 02:14 PM
milz's Avatar
I first tried the jumping the 12 pin connector as described in my haynes book,when that didn't work I bought an actron code scanner which is supposed to work with the 1994 LT-1, that did the same thing. Thanks for the responses, keep them coming.
Old Oct 1, 2006 | 02:35 PM
2001NBMZ28's Avatar
Just glanced at their site, for 94/95 GM they ask for more car info - sure they sold you the right one? You have power to the connector and the CIG/ACCY fuse is OK?
Old Oct 1, 2006 | 02:52 PM
milz's Avatar
New to this, not sure what you mean, the vehicles on the instuction book definately name the camaro 5.7 as one it will scan.
Old Oct 1, 2006 | 03:18 PM
2001NBMZ28's Avatar
OK, this is what I was looking at: http://www.actron.com/product_detail...id=16152&id=18 Check the fuse either way, might need power to work - now I understand about the flashing - it's evidently supposed to do that, just not familiar with their product.
Old Oct 1, 2006 | 03:47 PM
moparman's Avatar
Here's the bad news. The Actron code reader will not work with the LT1. I know it says it will, but it won't. I'm assuming this is the one that costs around $30.
Old Oct 1, 2006 | 03:50 PM
milz's Avatar
That's the one, shouldn't the jumper wires work though?
Old Oct 1, 2006 | 06:24 PM
moparman's Avatar
'93 was the last year the jumpers would work. You'll need a real OBDI code reader or OBDI scan tool to pull the codes.
Old Oct 1, 2006 | 09:48 PM
The Haynes book is wrong, the Actron info is wrong. Three people above have given you the correct answer. 1993 was the last year for shorting the pins - and that's all you get with the Actron you have, a fancy box with a switch that serves the same purpose as a 1-cent paper clip. Maybe a 4th identical response will convince you
Old Oct 2, 2006 | 09:17 AM
milz's Avatar
Like I said, I'm new to this, I'd much rather spend the money to buy a tool that I can possibly use later then fork over $$ to my local chevy dealer for a scan. Everyone is telling me what won't work, give me a recommedation of a scan tool that will work.
Old Oct 2, 2006 | 10:49 AM
rngilliland's Avatar
I use the Actron CP9150 to scan my 94. It includes obd1 and obd 2 cables. This is a link to the place I bought mine.
http://www.tradervar.com/cgi-bin/sto...age=cp9150.htm
