383 tune
Old Jul 25, 2006 | 11:41 PM
jeffs383's Avatar
383 tune
I just finished building my 383, it has 42lb injectors, forged internals trickflow heads, comp 230 / 236, .576 / .570 113 LSA cam, anyways, im using lt1 edit for tuning, and i've changed the injector size from the stock 24lb to 42lb injectors and changed the displacement for the 383. Anyways im still running rich, my blm's are 108 everywhere, and it seems like im running alot of advance, alot more then what i think i should be running. Any help would be appreciated. oh and im still using the maf
Old Aug 3, 2006 | 10:50 AM
QICSAN's Avatar
Re: 383 tune
Do you svo's or accel's? you have to change the "inj offset vs volts" to match the injectors being used.
Give me a shout I'll get you straighten out no problem.
LJ
Old Aug 3, 2006 | 10:59 AM
Honda Hunter's Avatar
Re: 383 tune
Subscribing
Old Aug 3, 2006 | 11:44 AM
GetaZforgetGT's Avatar
Re: 383 tune
No experience with this but some have said that leaving the displacement at the stock setting makes for a better tune.
Like I said, I have no first hand knowledge but a search might turn more up.
Old Aug 4, 2006 | 05:02 PM
jeffs383's Avatar
Re: 383 tune
im using lucas 42lb injectors
Old Aug 4, 2006 | 05:53 PM
Dan K's Avatar
Re: 383 tune
What injector constant are you using, and what rail pressure?
Have you modified the ve table, or the maf table from stock?
Old Aug 4, 2006 | 11:19 PM
jeffs383's Avatar
Re: 383 tune
I havent changed ve tables, or maf tables yet, i have it set for 42lb injectors, im still running the stock fuel pressure regulator. I havent adjusted inj.ofset vs. voltage
Old Aug 5, 2006 | 09:48 AM
Dan K's Avatar
Re: 383 tune
You need to find out what pressure your injectors are rated at and what your actual rail pressure is so you can set the injector constant correctly.
That's where you should start.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Killer94z
Jan 13, 2015 12:06 PM
