%change to fuel/air ratio vs rpm @WOT table
Old Jul 23, 2006 | 09:34 PM
plan Z's Avatar
just wondered if i should adjust this table. i noticed it was different from stock and i have a dip in my a/f ratio between 4500-5200rpm i'm trying to work out.
Old Jul 23, 2006 | 10:00 PM
Dan K's Avatar
Re: %change to fuel/air ratio vs rpm @WOT table
...only if you're using a wideband to get accurate data.
Old Jul 24, 2006 | 07:35 PM
wicked_95z's Avatar
If I am wrong please correct. But you if you want to lean out your A/F at WOT you subtract from this table at the apporpriate RPM range. If you want to richen it up you add to it. And dont you also want to make smooth gradual changes over the table or does that just apply to the MAF tables??
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
captcorvette
Mar 7, 2015 12:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
