How to Disable PE mode?
Old Jul 12, 2003 | 07:47 PM
96speed's Avatar
Question How to Disable PE mode?
How do you disable PE mode with LT1edit?
Ryan
Old Jul 13, 2003 | 09:01 AM
rskrause's Avatar
Moderator
Re: How to Disable PE mode?
Ryan
Depends exactly what you want to accomplish. But if you zero out the PE tables that will prevent any fuel from being added.
Rich Krause
Old Jul 13, 2003 | 03:47 PM
JSK333's Avatar
In TunerCat there is a "MAP WOT Enable" constant. I imagine there is something similar in LT1_Edit.
It is a constant of how much MAP is required before PE mode can be entered based on throttle position.
It's set to 15kpa stock. So just set it a good bit over 100 and you'll never enter PE.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Aug 7, 2015 08:52 AM
