Please help with computer problem.
Ok I've been battling this problem since i finished the whole winter project. I went and had it looked at where my friend works at. They scanned it and found that it was throwing 7 or 8 different codes. The car is just studdering like crazy and sounds like its gonna fall flat on its face. Could my whole pcm chip be bad or would it be a short somewhere? Im thinking that a short would only throw 1 or 2 different codes not 7 or 8. It might have been a voltage spike or something that would have caused the pcm to take a dump.
94 z28(A4),slp 1LE Elbow,TB Bypass,MAF Screen removed,160 degree thermostat, moroso cai,hooker lt's(jet hot coated),3in true duals,x-pipe,bullet mufflers,zex nitrous kit(75-125),Performance Transfer 3.73's, E.T. Streets, HPP III,NX purge kit,MSD 6AL Ignition ,NGK TR6's,BMR subframe connectors,Taylor Spiro-Pro 8mm,Hayden trans cooler, deleted: tire, jack, A.C.,and emissions
14
Aug 11, 2015 12:03 PM
