obd2 trouble codes
Old Jun 2, 2003 | 12:03 PM
5H9D0W's Avatar
obd2 trouble codes
I had auto zone scan my pcm.I got trouble code p0171 and p0507.Where can I figure out specificley what they mean.
Old Jun 2, 2003 | 12:43 PM
madwolf's Avatar
P0171: Oxygen Sensor System Too Lean Fault Bank A
P0507: Idle Speed Control Engine Speed High Fault
Old Jun 2, 2003 | 12:49 PM
5H9D0W's Avatar
What should I fix.
Old Jun 2, 2003 | 12:53 PM
madwolf's Avatar
Does your car idle high? When was your last tuneup? (plugs/wires/etc)
Old Jun 3, 2004 | 05:25 PM
imd1's Avatar
Angry
I have one of those codes also, however, the checking of codes by an auto parts store is prohibited here in Miami-Dade county for some odd reason. Anyway that was just a secondary thought in case one of you ever run accross someone else in Miami. So I purchased this scanner (http://www.actron.com/cgi-bin/web_st...d=8950502_7131) POS IMO. You can't monitor sensor values in real time as with other scanners, but I got the P0507 code as well and my car (97 SS) does idle high 950-1100 in neutral and about 950 in gear most of the time. When first started it races at about 1800 for a moment and takes several seconds to gradually drop to the above mentioned RPM's. I have replaced the IAC and TPS. Still getting the code. My next step is to lube the throttle plate shaft incase my cleaning the throttle body caused it to stick and then check for vaccum leaks then EGR. If anyone has other suggestions I am open to them. Sorry this was so long. I thought this may help us both. Thanks in advance.
Old Apr 26, 2007 | 03:01 PM
Z28x's Avatar
I just got the same thing on my 2000 Silverado.
What is the most likely cause?
Old Apr 26, 2007 | 04:01 PM
moparman's Avatar
Here's the GM code definitions: http://service.gm.com/gmspo/mode6/index.html
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
