why cant i read using tunercat ? used to read just fine
Old Jun 22, 2003 | 09:42 PM
sideways_Into_3rd's Avatar
my Tunercat used to read and flash JUST fine .. but recently i cant get it to read my pcm for the life of it !! i keep getting "wrong message sent" And it aborts reading ..
i cant trust it to flash my pcm if it wont even read
i restart into dos mode for reading and thats always worked for me ! i have no idea whats wrong .. tried 2 laptops, 2 cables .. no luck !!
Old Jun 22, 2003 | 10:06 PM
turbo_Z's Avatar
have you tried resetting your computer?
what windows are you using? version of tunercat?
Old Jun 22, 2003 | 10:15 PM
yeah restarted the laptop a few times ..
tried it both in windows and dos mode.. on 2 different laptops running win 98 and xp
not sure on the version of tunercat .. i'll check on that
but i've read and flashed my PCM over 50 times without any problems whatsoever !
come to think of it ... i did crash the car since the last time i did any tuning .. airbags went off .. it was a mess
could the impact have caused any problems related to this issue ?
mind you, i forgot to mention that i can scan the car without any problems .. freescan and TTS both work flawlesly !!?
Old Jun 22, 2003 | 11:17 PM
turbo_Z's Avatar
actually i meant resetting your PCM but oh well
your cable seems to be alright since you can use datamaster so you can rule that one out.
now windows XP you wont be able to use the DOS based flshread and flashprog programs but instead youll have to use that windows based flash.exe.
win 98 should work though in DOS so you got me there but i am sure if you cant get it to work with XP using those DOS based programs is why.
i dont think the wreck has anything to do with it but you never know. i guess you could rule out the cable and software if you can get it all to work on a friends car.
Old Jun 22, 2003 | 11:44 PM
hmm i just rememberd that tunercat came up with a windows based PCM read and flash utility !!! i totally forgot about using that one
can u link me to it ? thanx
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
