A4 Transmission Settings
Can anyone share any settings that you're used for your A4?? Advice?
I'm looking at the Down Shift Pressure modifier tables. Does this control the firmness of the downshift?? If so, what kind of value would I enter to make it softer??
If you want it softer lower the line pressure.
Are you modified? Does your car make power at or above the current shift point?
You could change that, most people increase their line pressures though...
I autocross my car and would like for the downshifts to be as smooth as possible. That's why I was wondering about the Downshift Pressure Modifier tables. The stock table has zero's in it for the 2 --> 1 downshift. The 3 --> 2 downshift does have some values. It appears it does add or subtract from the main line pressure. I'm just not sure what I should try. I might start with what they have for the 3 --> 2 shift and see what happens.
