Code P1107?
Old Jun 20, 2003 | 08:09 AM
ScWS696's Avatar
Code P1107?
Ive gotten this code more than once the last couple of years.Delayed upshift and low RPM stumble are noticible problems.I have tried two different maf's with same result after time.Also tried cleaning both MAF's and it comes back with time.
I have pcm 4 less tuning and LT1 edit for OBD2 .The car is a 96 T/A WS6 with LT4 hot conversion,300 stall hooker LT's,MSD 6A,ETC. Oh also this code will have P0300 Misfire code with it ,and I have the misfire light turned off .I still dont get that one.Any help would be appreciated I'm at my wits end here.
Old Jun 21, 2003 | 10:32 AM
P1107 Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
You need to be looking at the MAP, not MAF.
Old Jun 23, 2003 | 06:44 PM
ScWS696's Avatar
Thanks for your reply ,your right MAP not Maf.Any idea what causes this code ?Maybe the sensor is just bad.My car only has 42000 miles on it .
Old Jun 23, 2003 | 10:29 PM
Intermittents are tough. If you have actually changed the MAP before, I would say it is wiring/connection.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
