TunerCat injector offsets for 93's
Old Jun 10, 2003 | 10:47 PM
OutKast's Avatar
I'm getting ready to install a set of 42# injectors and I'm having trouble finding an injector contants table in TunerCat. I do see where to change the flow rate but I've been told that there should be a table for the constants as well. Any help would be appreciated. Thanks
Old Jun 10, 2003 | 11:03 PM
OutKast's Avatar
I'm running the ECM_DA3 definition file.
Old Jun 10, 2003 | 11:27 PM
madwolf's Avatar
The offsets are defined on the 94+ cars. The 93s only have the flow rate.
Old Jun 11, 2003 | 01:57 PM
OutKast's Avatar
Thanks madwolf.
What you recommend the setting to be for 42#/hr SVOs (green tops).
I used the formula of 42x1.07 to get 44.94 but I feel that's a little high.
In another forum someone suggested I use 38.2#/hr
Old Jun 11, 2003 | 02:39 PM
madwolf's Avatar
44.24 is the value you should use.
42 * sqrt (43.5/39.2) = ~44.24
Old Jun 11, 2003 | 04:23 PM
KCFormula's Avatar
How do you tune '93s with tuner cat?
Old Jun 11, 2003 | 04:28 PM
Dan K's Avatar
What are you trying to tune?
Fueling is taken care of by the VE tables since there is no maf sensor. Timing is the same, heck...most of the other tables are the same as the EE and EEB files.
Old Jun 11, 2003 | 05:50 PM
OutKast's Avatar
well shoot now I've got 3 different numbers that I've been given for the flow rate and they all have good reasoning for why they are that value.
Does anyone here run 42s in a 93? If so, what did you set the flow rate to?
I plan to put them in with the correct flow rate them use vemaster to tune in the tables.
Old Jun 11, 2003 | 05:53 PM
madwolf's Avatar
Think about it this way. The SVO injectors were rated as 42 lb/hr at 39.2 PSI (Ford pressure)
Our cars run at 43.5....
The formula is:
New flow rate = Old Fuel Rate * Square root of (New pressure / Old Pressure)
Old Jun 11, 2003 | 07:03 PM
OutKast's Avatar
Sounds correct to me. I will start with your value and go from there if needed. Thanks for the help.
Old Jun 12, 2003 | 10:25 AM
KCFormula's Avatar
So if I buy Tunercat, I can just hook it up with my ADAL cable and tune the (ie) timing? I thought I needed a chip burner?
Old Jun 12, 2003 | 11:19 PM
Dan K's Avatar
OK, my bad. When you said tune I was thinking of actually modifying a bin file, not actually uploading a progream into the car.
Madwolf posted everything that you'd need in a post a couple of days ago in this forum...
13qtr
Oct 28, 2016 08:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
