140 IAC Count from Scanmaster??
Old Jun 29, 2003 | 04:40 PM
94ZVert's Avatar
I was checking everything out today, and I noticed that my scanmaster was giving me reading of 140-143 for the IAC at idle. The cam is a CC306 and it idles "well" through a BBK 58mm TB. Is this a glitch in the Scanmaster as it should read 40-ish, or should I be looking for something? I was under the impression that the IAC topped out at 40. Anyway, does anyone else's Scanmaster give them faulty readings? Thanks.
Old Jun 29, 2003 | 06:31 PM
96z's Avatar
96z
The IAC is ideal at 40, it can go up as high as you stated if it wants AFAIK. Adjust your IAC table or open up the TB blades a bit. How is your idle in general?
Old Jun 29, 2003 | 06:41 PM
94ZVert's Avatar
I "think" it's OK. I've never been in a cammed car before and the CC306 is a little lopey. It's never given me any reason for concern before, but then again I just may not have known better.
Also, if I'm reading 140 which is high, why would I want to open my blades more? I thought 140 would be the equivalent of WOT. Thanks.
Old Jun 30, 2003 | 11:50 AM
The IAC motor keeps opening in steps until the idle speed comes up to where it is supposed to be. When it opens, it lets in more air through the IAC passage. If you start opening up the throttle blades, some air comes in thru the blades, and less has to come in through the IAC passage, so the PCM closes down the IAC motor. If you keep opening the blades, it will eventually go down to where ever you want it (20-40). Hopefully you have programmed to compensate for MAP being higher than the stock cam, to avoid surging at idle.
The IAC count is an 8-bit field, so in theory it could go as high as 255.
Old Jul 3, 2003 | 08:52 PM
REPO's Avatar
I am no expert, but on my OBDI setup, the IAC seems to peg at 160.
I had to open my blades a tiny bit to bring mine down under 100. But I plan on doing the BBK modification so the idle air goes into the intake, and not at the throttle blades. I hope this may help a bit.
REPO's Avatar
Old Jul 3, 2003 | 10:03 PM
94ZVert's Avatar
What modification would that be?
Old Jul 3, 2003 | 10:37 PM
REPO's Avatar
This one!
http://www.hashmarks.com/techtips/throttle_body_mod.htm
Old Jul 3, 2003 | 10:38 PM
REPO's Avatar
This one!
Nayr
Mar 3, 2023 08:34 PM
G-BODYT56
Jan 14, 2022 11:14 PM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
