Spark advance under boost question?
Old Jun 19, 2003 | 07:23 PM
Rico's Avatar
What kind of spark advance should I be seeing with my blower setup @ wide open throttle.
...Rich
Old Jun 20, 2003 | 01:35 AM
Highlander's Avatar
Depending on compression ratio.. I have 26 with 10psi and 9:1 CR
Old Jun 20, 2003 | 10:04 AM
Rico's Avatar
OK cool, I see about the same, with about 2 degrees of knock, is this bad.
...Rich
Old Jun 20, 2003 | 10:48 AM
Highlander's Avatar
Its not a good idea to have knock.. knock is a fail safe for avoiding major troubles when the engine is not in either optimum condition or not properly tuned...
So if there is knock most likely one day it will break...
Old Jun 20, 2003 | 10:57 AM
Rico's Avatar
K thanks.
...Rich
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Noenav
Dec 6, 2014 07:35 PM
