tuning advice
Old Jun 22, 2003 | 05:16 PM
oldsalt's Avatar
tuning advice
i have a 94 383 with lt4 heads , intake, hotcam, 1.6 rr, tpis full length headers, 10 psi SC , 36 lb injectors, crane ign with boost retard.
i am having a very hard time tuning this setup. any one have any good tips on tuning. i have tries maf table adjustments, ve table adjustments, open loop ,closed loop and still cant seem to get it right. i seem to have tried all kinds of ombos and cant get it right so i thought i would start from scratch. if anyone has a similar combo chime in and give me a hand...thank you , i really want to start driving this thing, it has been down for two years on the build up now i still cant drive it.
Old Jun 22, 2003 | 05:45 PM
Camaro_SS/R's Avatar
Are you tuning it on the dyno with WB O2? With a 383 and if you are seeing 10#, then your 36#/hr is highly not sufficient. Even if you have a FMU, you will not be able to make it. I would definitely throw it on the dyno so you can follow the A/F and maybe misfires and other parameters while you are running the car. The benefit is that if you see the A/F going pass 14 you can stop right away and not blow anything.
I would definitely consider getting some bigger injectors especially if you are hitting around 500rwhp.
Make sure you check out
http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
http://www.caspeed.com/lt1/index.html Allen has a sample of his LT1 file for his SC 383.
http://www3.baylor.edu/~Christopher_...ht/LT1Edit.htm
good luck
Old Jun 22, 2003 | 07:51 PM
rskrause's Avatar
Moderator
Re: tuning advice
It would help to know what is doing. As "oldsalt" suggested, your injectors do seem small.
Rich Krause
Old Jun 24, 2003 | 10:11 PM
Highlander's Avatar
VERY SMALL!!!!
Firechicken350
Jun 6, 2015 11:25 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
chuyz28
Apr 9, 2015 09:36 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Killer94z
Jan 13, 2015 12:06 PM
