Questions about Tunercat
Old Jul 4, 2003 | 06:11 PM
rskrause's Avatar
Moderator
I want to try Tunercat, but have two questions.
1. Where you get the defintion files? It was easy to download the trial version of the Tuner, but I don't see the definition files on the site.
2. I vaguely recall that there is some kind of compatibility problem with using Tundercat and LT1_Edit. If I modify my file with Tunercat, will I still be able to use LT1_EDIT?
Thanks.
Rich Krause
Old Jul 6, 2003 | 07:20 PM
SABLT194's Avatar
Rich,
You can convert files back and forth between Tunercat & LT1 Edit with a file conversion utility. Tuner cat is far cheaper and I've used it for some 91 TPI and Syclone programming. I've only ever used LT1 Edit on my 94 Formula.
Steve
Old Jul 6, 2003 | 08:56 PM
Z28ROC's Avatar
You can order the definition file, from thier site. It is $20 and they will email it to you. Tunercat has a paypal account also.
Old Jul 6, 2003 | 11:34 PM
Another Red Z's Avatar
I have used both on my car and have not have any compatibility problems . I bought TC for tuning my TBI truck and liked it better so I bought the def file for the car.
Old Jul 6, 2003 | 11:56 PM
Dan K's Avatar
Rich,
The definition files you get from TC. They also send you some other associated files along with the definition file that you purchase.
Also, the newest version of tunercat allows you to open LT1 Edit files directly...no conversion needed. Not sure about going back to an LT1 Edit file though. I don't think tunercat allows you to save as an LT1 Edit file though. Either way you can just use the file converter.
Old Jul 7, 2003 | 04:41 AM
rskrause's Avatar
Moderator
Originally posted by Dan K
Rich,
Where can I find the converter file?
Thanks.
Rich Krause
Old Jul 7, 2003 | 06:08 PM
Dan K's Avatar
In your e-mail.
BigWil
Mar 29, 2015 12:24 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
