Does a Bad Injector Driver Mean a Bad PCM?
Old Jun 18, 2003 | 04:44 PM
95 Z/28 LT1's Avatar
Super Moderator
I think I may have an injector driver that is acting up.
Are there eight of these in the pcm? What kind of scan could tell me if one of them is malfunctioning?
The problem is intermittent and will cause the engine to run rough about every other time I drive it.
I had a bad PCM ground for a while and I think it caused something in the PCM to ruin itself. I was busy changing all kinds of other things that I thought could be wrong with the car and finally checked the PCM ground and it was REALLY corroded.
Does anyone have any experience with this sort of problem?
Old Jun 18, 2003 | 05:05 PM
madwolf's Avatar
Yes, the injector drivers are in the PCM. Try another PCM and see if the problem goes away. If it does, just replace the PCM.
Old Jun 18, 2003 | 07:54 PM
Super Moderator
OK.
How much for a loaner PCM with the option to buy it?
dale3in98
Feb 14, 2015 12:18 PM
Jan 5, 2015 07:14 PM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
