Fuel map,Timing table.....
spark map
Tuner guy is coming over. He asked me to get a timing table. Please help. I am putting in 30 lb svo's. Cam is xe218/230@112. Heads are 260/197. Long tube headers,stock short block. .026 head gasket, 93 octane fuel,M6. Is stock fuel pressure 43 or 43.5? Is ford 39 or 39.5? Thank you. Tim
With your combo, the stock map will work fine to start. You'll need to tweak the wot timing though.
As far as part throttle you could probably add a degree or 2 here and there. It's just something you're going to have to experiment with.
Alex Barnes
Jan 24, 2015 10:21 PM
