tunercat injector help needed
Old Jun 17, 2003 | 08:54 PM
thumpinTA's Avatar
I am all set up and have succesfully read my PCM. The first thing i wanted to do is change my injector flow rates for svo 30lbs. From what i have read you go to ecm constants then injector flow rates. I can not find these listed anywhere. Under tables it seems like i am not able to display all of them because it goes off the screen. Anybody else have that trouble? Am i looking in the right spot (under tables).
94 ta
Old Jun 17, 2003 | 11:01 PM
m0nk's Avatar
Try maxamizing the tunercat window on your screen, then go to tables, the second one down is ECM Constant Table. If you are having trouble seeing the pulldown window, try increasing the resolution on your screen.
When you get to the constant table, injector flow rate is the 2nd constant, under cylinder volume.
Old Jun 18, 2003 | 09:38 PM
thumpinTA's Avatar
Monk, thanks for the reply that worked. Do you or anybody know why my pcm read shows my flow rates at 793.46 ? If that is a default # how would i find out what it is really set at?
thanks
Old Jun 18, 2003 | 10:03 PM
madwolf's Avatar
If you're using the EE definition, switch to the eeB definition in the ECM menu. Or if you have eeB now, switch to EE and try again.
Old Jun 19, 2003 | 01:09 AM
m0nk's Avatar
yeah same thing happened to me my first time, im like no way the flow rate is 700 something, so I just changed to EE and it worked fine.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
