Who uses OBDII on their modified LT1?
Old Jul 5, 2003 | 01:58 PM
zhevy-1's Avatar
Hey guys, I just wanted to get caught up on what's going on with the OBDI and OBDII PCM's latest tricks.
I have the OBDI convertion on my 1996 Z28. I'm refreshing my 383 with new rings, cam, valves, and additional port work, and the shop that is doing the work -my friend Peter- can do a great job on OBDII tuning. (Dyno-tuning onsite).
My question is, should I stick with my OBDI convertion, or should I go with the OBDII programming?
Thx-Goose
Old Jul 5, 2003 | 02:10 PM
madwolf's Avatar
If you don't have to pass emissions, stick with the OBDI.
Old Jul 5, 2003 | 02:31 PM
zhevy-1's Avatar
I take it there hasn't been enough progress on the OBDII world in the last 3 years or so, that would make a choice like this, a toss up?
My car is set up so that either the OBDI or the OBDII are plug-and-play. OBDI has the knock sensor mod so, I can still have the 96 KS in the motor, and 02 simms on the rear cats.
Wondering, if more power can be squeezed on one over the other when it comes down to a dyno-tuning.
Old Jul 5, 2003 | 02:56 PM
madwolf's Avatar
If your friend only has OBDII tuning software, you could get it dynotuned on the OBDII, then copy over the air to fuel ratio to the OBDI.
The OBDII can be programmed just as the OBDI, but it is more picky and I personally preffer OBDIs.
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Lt1son
Dec 22, 2014 10:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
