I have windows 95, do I need to upgrade
Old Jun 21, 2003 | 10:17 AM
krazwag's Avatar
Got a laptop but it's kinda old. It has133mzh, 32 ram, with windows 95. I can run freescan but when I hook up tunercat it keeps saying "no message sent cable failure". I have a new cable from AKM cables and the connections seem tight so I was wondering if I need window 98 or 2000. Anybody else have and knowledge on this. Thanks
Old Jun 21, 2003 | 10:41 AM
m0nk's Avatar
I had this problem while trying to use a friends laptop before i purchased mine. He was running winxp so it wasnt that. Try using the help guide.
http://www.akmcables.com/serial.doc
It got mine working.
And all winxp will do is make your computer run slower because it uses more resources
Old Jun 21, 2003 | 06:33 PM
rage366's Avatar
nope, u can use it on win 95....
Old Jun 24, 2003 | 12:07 PM
FireAm94's Avatar
His processor isn't fast enough for windows xp nor does he have enough ram either.
Joe
Old Jun 24, 2003 | 12:34 PM
SteveR's Avatar
Keep using 95. 98 is too unstable, and will slow it down a LOT (as will any later OS). Make sure you don't have FreeScan running when you are trying to connect with TunerCat. I recommend that you use the DOS software when loading files to your car...that can eliminate a lot of potential problems, and it will be a lot more stable. Don't just run a DOS window, actually shut windows down (exit to DOS).
Old Jun 24, 2003 | 12:46 PM
FireAm94's Avatar
Windows 98 SE is LOTS more stable than windows 95 (original service release and even version 2.5 or C) and Windows ME was probably the most unstable out of them all hehe. We have alot less trouble out of Windows 98 Second Edition than 95, ME.
Joe
OutlawPerforman
Oct 30, 2017 05:40 PM
97SSdude
Aug 21, 2015 09:36 AM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
Jul 10, 2015 02:23 PM
