Transmission line pressures
Is it bad to have transmission line pressures high? Like in the lower TPS% range, when you're just crusing, is there any extra wear on the transmission to be running w/ higher pressure there? I think I heard it is better for the clutches to shift firmer though.
I got this information from TCI...
700r4
Range Minimum Maximum
Park 90-110 190-230
Reverse 95-120 200-300
Neutral 90-110 190-230
Overdrive 90-110 190-230
Drive 90-110 190-230
Second 185-230 185-230
Low 185-230 185-230
700r4
Park 90-110 190-230
Low 185-230 185-230
Jul 4, 2005 05:00 PM
