Cell 18 for anything off idle?
Old Jun 24, 2003 | 09:11 AM
quicksilver97ta's Avatar
Just got a laptop and cable, I downloaded freescan and pccomm and monitored the PCM with each. I'm working with a mail order tune and just checking things out sitting in the garage watching these programs (one at a time). I've got knock, no doubt about it, and I want to get programming software to work on that.
One thing I noticed is I was in cell 16 while at idle but any rpm above that it would go to cell 18 only. I could hold it at 2k, 3k, give it a wot burst, and still just cell 18. What is the deal with that? Also, is there a way to look at the different cells without the car actually being in them, IOW, can I just pull them out somehow?
Also, I noticed tunercat (web page) appears to have multiple programs (read, edit, flash, ect) do you get all of them with purchase?
Old Jun 24, 2003 | 10:02 AM
turbo_Z's Avatar
you only see cell 18 because you didnt reach closed loop yet... give it a few minutes and see what happens. as far as the tunercat.. i believe when you buy the tuner you get the flash utility that will read and reflash your PCM. im not 100% sure since i had the flash utility before tunercat but i know you can select the flash utility in one of the menus up top so that leads me to believe its just included.
Old Jun 24, 2003 | 11:22 AM
Alright, I'll look again and make sure its in closed loop (but i thought it was). I've read about locking it in closed loop, so I wonder...
Also, is there a way to look at all the cells at the same time? like in a table or something? How does datamaster differ from freescan and pccomm?
Old Jun 25, 2003 | 10:52 AM
I guess its just an M6 thing because its definitely in closed loop however, once I hit the road it does go into the other cells.
Old Jun 25, 2003 | 11:21 AM
bunker's Avatar
sometimes when you are running too rich hanging out in the 108 blm range it goes to cell 18, I guess that cell listens to the VE table since the MAF no longer helps.
Old Jun 25, 2003 | 11:25 AM
383Z4ME's Avatar
Not an M6 thing! You need to read more first. http://para.noid.org/~lj/
has a really good programming tutorial and
Fred's site
http://members.aol.com/InjuneerZZ/Index.htm
has some good information.
Old Jun 25, 2003 | 12:05 PM
turbo_Z's Avatar
yeah i take back what i said.. yesterday i drove home(about a 10 min drive) and it stayed in cell 18. i pulled the face all the way home. guess that CCP was the culprit.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
truecontr3
Oct 11, 2015 09:30 AM
Double aught
Oct 2, 2015 11:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
