How do I make a '94 LT1 OBD2?
What sensors differ from a 94Lt1 and a 96-97LT1?
I have a 98 camaro and im putting in a 94 LT1. The 94 PCM is OBD1 and I would like to keep it OBD2 for emissions reasons. What all will I need other then a PCM to convert it to OBD2?
emission wise, both motors are the same. as far as the wires go, the ob2 motor has a crack sensor and 4 os instead of two. i sure there is something else! i would just run the 94 9cm and not worry about it
i think you FUBARED that one up
