Spark advance!!!
Old Jun 24, 2003 | 09:26 PM
Highlander's Avatar
Spark advance!!!
I am having a bit of trouble with the spark advance.. The PCM is advancing more as rpms go up yet my extended spark tables are set straight and in other instances lower...
What can I do for the PCM to keep a constant spark advance???
Old Jun 27, 2003 | 12:46 AM
95Blackhawk's Avatar
More details please. What is your coolant temp at the time? and is your computer modifying the timing tables based upon this temp? do you have KR? What are the conditions?
This may help us answer.
Ben
Old Jun 27, 2003 | 12:51 AM
Highlander's Avatar
80-84C
The computer has the correction to 0 on those temp ranges and no knock retard...
I found out that the PCM adds 2 degress up to 4000 at 4500 its 3 and at 5500 its 4.
jwade88
Jun 14, 2015 09:38 PM
zxtce
May 7, 2015 08:53 PM
blkWidow
May 3, 2015 08:42 AM
charchri4
Apr 14, 2015 06:40 PM
