lean on a 75 shot
Old Jul 12, 2006 | 06:24 PM
karl81talt1's Avatar
lean on a 75 shot
I have tried a wet 75 shot on my car twice now and its been going lean both times. According to the plugs (white as hell). At first i tapped the fuel before the injectors so i thought it was robbing them of fuel so i moved the fitting to after the regulator, but the plugs are still white. I have a walbro 255 and the fp is set to 45 with the line unhooked. Have not had access to an external fp gauge but the gauge under the hood goes to about 60 when revving the motor. The car feels real good (lean) but i dont like it with almost 100k and a stock bottom end. Any help is greatly appreciated. Thanks
Old Jul 12, 2006 | 07:26 PM
DrewHMS97SS's Avatar
Re: lean on a 75 shot
bump up the fuel jet
Old Jul 12, 2006 | 07:30 PM
nos recomemded a 40 n2o and a 26 fuel. I already have a 28 jet in the fuel. I was going to try a 30 soon but was just curious if any one else had the same problems.
Old Jul 13, 2006 | 03:06 AM
Joe B's Avatar
When I ran the 75 shot , I was using a 40 nitrous and a 28 fuel , same as NOS recomended in their book for the 75 aproximate RWHP shot.......this was plenty rich for mine as it is designed to be......you really need to get a visable manual fuel pressure gauge on there while making a full pass(NA) to see EXACTLY what the fuel pressure is doing under load gear after gear......also make sure of where your total timing is set, pull a few (3-4) degrees if you can....(and if you haven't already)go to a one step colder plug gapped at 35thou........
Old Jul 13, 2006 | 03:07 AM
Joe B's Avatar
Joe B's Avatar
Old Jul 13, 2006 | 03:20 AM
a good rule of thumb on timing is 2 degrees per 50 shot. It is over kill in most situation but again is a good place to start. If you have not pulled timing, that is your problem, if you have, bump to 30. Every car runs a little different which is why there is so much difference between tunes and so on.
Old Jul 13, 2006 | 03:28 AM
Daniel6718's Avatar
did u remove the schrader valve when u put on the fuel line to the solanoid?
Old Jul 13, 2006 | 08:38 AM
HarrisSpeedWorks's Avatar
Are you pulling the plugs out to read them as soon as you make the pass?
Matt
Old Jul 13, 2006 | 06:39 PM
n2oCamaro's Avatar
Matt
Yeah, you basicallly have to turn the engine off right after you cross the finish to get an accurate reading on the plugs
Old Jul 21, 2006 | 12:36 PM
Sweetred95ta's Avatar
What a/f would you guys consider to be lean while spraying? May want to take it to a dyno and see what it is doing using a wideband.
Old Jul 22, 2006 | 11:12 PM
n2oCamaro's Avatar
13.0 and up.
Old Jul 27, 2006 | 02:41 AM
gforcejunkie's Avatar
i would pull some timing on it 4 degrees should be right on the money. you could also check the size of the jets on other companies. most nitrous systems are very similar
68camaroboltz
Oct 5, 2015 11:56 PM
drt
Sep 27, 2015 04:39 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
