timing retard
Old Aug 14, 2006 | 02:36 AM
nickp's Avatar
timing retard
I just upped my jets to 150. I have a digital 6. I have it set at 4.7 for the retard setting. Does this sound right ? Thanks for your suggestions. Nick.
Old Aug 14, 2006 | 11:19 AM
Moshbmx1's Avatar
Re: timing retard
2 deg retard for every every 50 hp you spray is the general norm. So spraying 150 would put it around 6. Play with it around 6-8 and see where it runs the best.
Old Aug 14, 2006 | 11:33 PM
Bandit 1's Avatar
Re: timing retard
I ran 3.5 degrees retard on a 150 with no problems. 1.5 degrees for every 50 shot you would want to pull more with a 150+ shot though
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
ScottZ
Mar 3, 2004 01:34 PM
