Throttle Body won't fit with TNT plate?
seems the bottom of the throttle body hits the thermostat housing once you put the plate on....I have a BBK 58MM so it's a bit bigger than stock...I doubt I'm the first person to run into this....how much grinding did you guys have to do and how much is "safe"?
Re: Throttle Body won't fit with TNT plate?
I had my kit installed and they informed me of the grinding that was required in order to install the package. I am sure that if you grind only enough to make it work it should be fine. TNT would probably know best as the design is theirs and they are aware of this step.
oldschool
02-09-2016 09:21 PM
