difference between ford and chevy universal nx kits
Old Jul 8, 2006 | 10:58 PM
nonojoe66's Avatar
hey does anyone know what the difference between a universal nx kit for a ford and a nx kit for a chevy? im buying a kit from a friend that had it on his mustang and want to put it on my camaro, do i need anything to put it on the camaro or should it mostly be the same?
Old Jul 9, 2006 | 11:45 AM
2000GTP's Avatar
Re: difference between ford and chevy universal nx kits
I think everything will be the same except for how the fuel source is tapped. On the GM cars, you can just run a -4AN hose directly onto the Schraeder valve and then run that line to a 3/8-4AN conversion fitting off of the fuel solenoid.
Old Jul 9, 2006 | 06:00 PM
nonojoe66's Avatar
well i just picked up the kit, im assuming you have to take the shrader valve core out to put the line on? if so can you use a valve core remover for a tire for it?
Old Jul 9, 2006 | 09:26 PM
4mulaJoe's Avatar
Yes. Thin needle nose pliers work too.
Old Jul 10, 2006 | 08:30 AM
2000GTP's Avatar
Yeah, I had one of those tire core removal tools handy. It did the trick right away.
CARiD
Feb 9, 2015 09:35 AM
Jan 23, 2015 01:13 PM
CARiD
Dec 26, 2014 04:20 AM
NewsBot
Dec 3, 2014 12:30 PM
formula79
18
Jul 1, 2002 02:39 PM
