All those with NOS 5176 kit inside please
All right so heres the deal, we all know it gets extra fuel from the FPR and bumps the FP. What are you guys doing for durable FPR's? I blew my FPR up this w/e. It is shooting fuel back out of the FPR. The only thing I can figure is it couldnt handle the preasure of the nitrous. It is a stock FPR, and I am running a .073 nitrous jet and the .042 fuel tee. This set up is giving me 11.5 A/F.
Next question, Do any of you have problems blowing the hose off that goes to the tee and FPR? Mine as done this numerous times. Ive clamped the **** out of it and it still does it. Also I just recently converted the noid to tee hose to brake line because the nitrous would freeze and crack the hose then blow nitrous out the cracks. Am I just running to big of a shot through this system?
Re: All those with NOS 5176 kit inside please
You are running the nitrous signal through the blue pressure regulator, and then to the tee in the line to the FPR??? It sounds like the blue pressure regulator may not be working, and the pressure in the line to the FPR is too high. That would explain both of your problems. You do not want to apply full nitrous pressure (900psi) to that line or the FPR.
So...... what do you have? Do you have the blue pressure regulator in the system? If you do, you have to find a way to see what the pressure is in the line from the pressure regulator to the tee in the FPR vacuum line.
Here is what I had (fuzzy pic I know) This pic has the line going to the copper tee. I know it says FPR. but it goes to the tee.
After the line froze I went to a brake line which is probably smaller than the hose going to the Tee. The hose going from the tee to the FPR is just like in the pic above.
Ill put a vacumm tester to the blue reg. and give you more results
Be careful.... if the blue pressure regulator isn't working, you could be seeing 900psi in that line. A "vacuum tester" might explode.
