Anyone tried the direct port nozzle systems?
Number one, Cold fusion kit, adjustable to 400 hp:
http://www.nitrousdirect.com/directportnitrouskit.html
Number 2, Nitrous express kit adjustable to 500hp:
http://store.summitracing.com/partde...ex-80010-10nxl
Number 3, NOS Noszle system, adjustable to 300 hp:
http://www.holley.com/08008NOS.asp
David
David
Re: Anyone tried the direct port nozzle systems?
Originally Posted by fast 93 z
I have used the NX one. I recommend not spraying more than a 200 shot through those type of NXL nozzles.
Reason being?
David
The shop the built my engine uses the NOS NOSzle system on their sub-7 second Pro5.0 Mustang. Before they decided to use it, they did some dyno testing to verify the NOSzle was not going to impact the injector in any negative way - e.g. altering the spray pattern. They were satisfied that it did not hurt anything. They were also skeptical about using the NOS nylon tubing for the nitrous, but that also turned out to be problem free as well.
Only caution.... they were only putting the nitrous through the NOSzle, prefering to run a dry system, as they do with 99% of the engines they build. Whether the NOSzle would have had a bigger impact on the injector when spraying fuel and nitrous was not tested. Obviously, they were spraying well over a 200-shot with the system, and probably (:wink
more than the 300-shot the system is rated at.
more than the 300-shot the system is rated at.I am not to keen on drilling and welding our intake(you probably know which one I am talking about) I have concerns on unknown paths taken as fas the above systems go, I aint gonna be a guinea pig on this engine for sure.
I saw a NXL system at a outlaw 10.5 race recently in Hattiesburg Miss on a big block 80 ish Malibu, it was running 5.30's, He was running the 5.30 index class, his kit was the first one I mentioned, here is a pic
Any input on these kits is needed.
David
We noticed when spraying it would cause a very rich condition. We would jet down on the fuel side and it would still stay at <10:1 A/F. My guess is when spraying it was causing a vaccum in the injector tunnel pulling more fuel from the injectors. Now we backed down to a 200 shot and lower and it worked fine. This was my experience.
Jul 4, 2005 05:00 PM
