Making Your Own Nitrous Lines?
Old Jul 4, 2006 | 11:18 AM
"White Knight"'s Avatar
I want to be able to make my own replacement nitrous lines. I have no idea of how to do this and would like to learn. What tools and supplies will i need to make stainless AN nitrous lines?
Old Jul 4, 2006 | 11:34 AM
Re: Making Your Own Nitrous Lines?
Here they show a little demo, but it doesn't look like this thpe of hose is what i want.
http://www.koultools.com/
Old Jul 5, 2006 | 09:58 AM
HarrisSpeedWorks's Avatar
You would need either a hydraulic crimp machine or a hand operated one, along with the dies for the sizes of hose that you wanted to do. Then you'll need the hose, collars, inserts, and end fittings.
Matt
Old Jul 5, 2006 | 10:15 AM
Do you know of any place that sells these crimpers. I have been looking and can't find one online anywhere.
Old Jul 5, 2006 | 03:20 PM
srsnow's Avatar
How many lines are you planning on making? You will have a few thousand dollars in machines and tooling. Not to mention where did you plan on buying the hose inserts and collars? You probably can't buy them direct unless you are buying in bulk. And if you did find a place that would sell them to you a few at a time it would probably cost about $4-5 an end plus cost of the hose which unless you buy in bulk could be anywhere from $2-3 a foot. I think you would be better of just ordering the lines. And if you need custom lengths I'm sure a lot of the nitrous companys offer custom length hoses.
Old Jul 5, 2006 | 05:16 PM
You might try a hydralic line supply house, but like srsnow said, be ready to spend some $$$. Just a heads up in case you didn't know, we do offer custom hoses: http://www.harrisspeedworks.com/shop/home.php?cat=261
Matt
Old Jul 5, 2006 | 05:55 PM
2000GTP's Avatar
Matt
Your custom hose option is one of the best offerings of your business in my opinion. It really came in handy for me.
Old Jul 6, 2006 | 01:56 AM
AF96Z28's Avatar
I had all my lines built by a hydraulic supply place. I dont have the fancy blue/red fittings, but they made lines for me and a few buddies right in front of us. It was extremely inexpensive too. I had like 7 lines made ranging from 36 to 12" for under $50
Old Jul 6, 2006 | 07:14 AM
Thanks for the heads up guys. I had no idea the tooling would be so much. I kindof just wanted to try it on my own.
Old Jul 12, 2006 | 02:06 PM
jaykar's Avatar
Hi,
A Vise
Some electrical tape
A Cut off tool with wheel-air or electric
And you'll be making all you want with no hassle.
Later
Old Jul 12, 2006 | 02:24 PM
srsnow's Avatar
Originally Posted by jaykar
Hi,
A Vise
Later
I hope this was a joke because if you tried to put nitrous through a line of that type it would get ugly
Old Jul 12, 2006 | 02:36 PM
jaykar's Avatar
I don't know how much experience you have had setting
up fuel-hydraulic-air ect; for high pressure using flex line
of all sorts and AN fittings??
I've owned a few shops, Cars and boats, and been using
Flex & AN for many years.
AN 4-6-8--1500psi Operating Pressure!
Your not going to use the cheap flex line for that that application. Just showing you don't have to get all the whistles and bells equipment to do it yourself.
Read up on assembly before putting keyboard to use.
later
Old Jul 12, 2006 | 04:30 PM
srsnow's Avatar
The problem is that your first statment was very vague. You made it sound like he could just go down to Autozone and get some hose and start making stuff. You need to know what the line is rated for that you want to use. You need to make sure that the parts you are using are correct for the wall thinkness of the teflon hose you are using. Also what size lines are you going to be making? -3 after a solenoid would probably be fine if it was assembled properly but a -6 will have a lower working pressure than a -3 and may not be a good idea to use as a feed line. Now do you want a line that has the the same burst pressure as the saftey disc in the valve? There is a lot of what ifs when making lines that while normaly will only see 1000psi should be able to handle 3000psi before failing. If you are going to tell a guy that he can make his own line using reusable hose ends you can't be so vague because some one that has never done it before may go out and use the wrong parts and end up hurting himself. If the line was assembled wrong and the fitting came off it could cause some major injuries. I can appreciate you wanting to give someone an option other than what has been posted but a little more info may help them to understand what they are getting into.
Old Jul 12, 2006 | 05:06 PM
jaykar's Avatar
A little vague, agree.
(A line of that type-Could get ugly.)
Be willing to bet that 50% or more N02 people make
up some portion of thier lines using flex an AN fittings.
Should have realized that he was going to run down to
Autozone, buy a vise,some electrical and flexline or rubber
hose and start fabricating without asking any further questions
Not going to get into a p-----g contest with you and assume that most people on this board are smarter than
you give them credit for
Later
MadMav
May 25, 2015 09:35 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
